Insights Not Compatable with Enterprise 10.6.1?!
1667
12
08-17-2018 07:40 AM
DanielYaw_Jr__GISP
New Contributor III
ESRI support tells me that Insights is not compatible with Enterprise 10.6.1? I'm also kind of confused why ESRI would not make sure that insights is compatible with 10.6.1. Does anyone know when a compatible release is scheduled for?
DerekLaw
Esri Esteemed Contributor
FYI, Insights for ArcGIS v3.0 was just released today.
EDIT: Checkout this blog for details about the release, What’s New with Insights 3.0 (September 2018)
Hope this helps,
DerekLaw
WillHughes2
New Contributor III
The next release of Insights (3.0) will be supported on Enterprise 10.6.1.
DianaBenedict1
New Contributor III
When is the expected date for the release of Insights 3.0  I upgraded to 10.6.1 and assumed that all supporting components would work. ESRI should have really documented that better here. I did not find out until I was done with my upgrade. Now we are stuck because Insights does not work.
DerekLaw
Hope this helps,
SteveLewis
I had to add this in order to get InSights to connect to my SQL Server
Microsoft JDBC Driver 6.4 for SQL Server from
https://www.microsoft.com/en-us/download/confirmation.aspx?id=56615
Extract and drop this file: mssql-jdbc-6.4.0.jre8.jar  into:
*:\Program Files\ArcGIS\Server\framework\runtime\tomcat\lib
MikeJones7
New Contributor III
Is anyone able to download insights 3.0?  It's not; showing up on my.esri page.  My Customer Service Rep has been looking at it since this morning. I just need the link to the download?
SteveLewis
https://my.esri.com/#/downloads/Insights%20for%20ArcGIS/3.0
MikeJones7
New Contributor III
There's nothing under 'Download Components'
SteveLewis
This is what it looks like for me.
