Insights Analysis from Survey123 Service
3927
13
11-12-2018 06:57 AM
by Anonymous User
Not applicable
Hi, I am trying to analyze the results of a survey123 survey using Insights.
The information of that service can then be altered by other instances of the workflow, for example error records can be eliminated.
When viewing the data in Survey, Map Viewer or ArcGIS Pro I get only the valid data. However, when I open the service in Insights it  display's all the records, even those that have been deleted.
Is there any way to avoid this behavior?
Thank you.
AllisonMuise2
Jon Emch‌ this has been logged as Esri Case #02628444 - Accessing data in Insights on Enterprise 10.6.1 shows more records than exist in the source feature layer
JonEmch
Very good, I will work with the analyst to assist you, or take over the case myself at their discretion.
Keep on keeping on!
JonEmch
For transparency, I am following up on how this case was resolved.
After some testing I was able to confirm the following:
  • This issue no longer occurs at Insights 2020.2 running Enterprise 10.8.1.
  •  The issue does occur at Insights 3.4 on Enterprise 10.6.1 and have logged BUG-000133701: ArcGIS Insights displays records edited via Esri mobile applications (Survey123, Workforce, Collector) on Enterprise 10.6.1 as uniquely added items
If your organization is running into this issue, I encourage you to log a defect with Esri Support to be added to the defect record in order to escalate its priority.
Keep on keeping on!
Ed_
by MVP Regular Contributor
Great question, thumbs up to OP.
Question | Analyze | Visualize
