Date/Time results in Insights seem to be in UTC time zone
2008
01-14-2019 02:47 PM
by Anonymous User
Not applicable
I started using ArcGIS Insights recently, and I love the functionality it offers.
But, something I noticed was - results seem to be in UTC time zone - when data is imported from a feature layer (not sure if this has only been happening since the latest ArcGIS Online update).
I also tested this by exporting the feature layer to a csv (where results are in UTC timezone by default) - and running the analysis in excel. And the date/time results were exactly the same as what was produced through ArcGIS Insights.
A fix on this would be greatly appreciated, or let me know if I'm doing anything wrong from my end.
Thanks so much,
Gee
by Anonymous User
Not applicable
Hi Art Haddad‌/ Linda Beale‌/ Kelly Gerrow‌/ Khaled Hassen‌,
This issue still seems to be occurring.
Also, do you guys know a way - on how to add 11 hours to a time field in a data table (when creating a calculated field)?
Thanks so much,
Gee
JonEmch
Geethaka Fernando,
   Thanks for reaching out! Could you reply with a step by step workflow of how you are able to reproduce this issue? I went through a similar workflow and found that the UTC function worked as expected.
   From my experimentation, I found that the UTC timecode can sometimes be based on whether or not you are linking to ArcGIS Online via a VPN. Are you able to reproduce this on a different internet connection / a different machine? Looking forward to your response.
Keep on keeping on!
CCGIS
Hi ArcGIS Insights team,
I have a formatted table and the dates on my table can't be converted to date in Excel. I have tried different things and nothing seems to be working. From reading different posts, I understand the date is in UTC. How can I create a table so I can download the CSV with the correct date format?
AkshayHarshe
@CCGIS Can you please elaborate on your workflow/problem. Are you exporting a dataset in insights to a csv?
Akshay Harshe
