Good day,
In "R" with packages such as "RMarkdown" I can export the script output as an HTML file. The good thing about an HTML file is that the plot/table/map is still interactive and does not require any script to run in the background while the HTML file is open.
I think it's pretty advantageous to embed HTML files in Insights online since it does not support scripting. And it would also good option to have in Insights Desktop too if you have big datasets.
Is it possible to add this as a feature?
I could have attached an HTML file for further reference if the option was available but it's not. However, I can email it if need be.
Thank you,
