I have a flooraware web map with referenced feature services in our ArcGIS Enterprise environment. I would like to create a dashboard for asset analytics. However, the floor filter is not included, and I can't add it to the dashboard. I've seen many images of flooraware dashboards, but how can I create one? Do dashboards support flooraware maps with referenced feature services, or only with hosted feature services?
I created a dashboard but had to configure the widgets with the floorplan data for it to filter - but in this particular case, the floorplans are only for one floor - so probably not helpful.
You can create a dashboard like app with ExB - someone shared this example: https://experience.arcgis.com/experience/9c385c26672f42e39e21613fa4d560bb/#data_s=id%3Awidget_217_ou... .
I am hoping that eventually dashboards includes the floor filtering widget!
Mary
Dashboards do not have a floor filter widget, but you can get around it by using Category Selector in the header or a side bar. You'll have to made a selector for your Site, Facility and Level layers. You can also do as Mary mentioned with an Experience Builder app instead, which has the floor filter widget, it just kind of depends on what the end goal is.
Here is a screenshot of a dashboard I made using the Category Selector method in the header.
