Floor filer widget not showing sites and facilities list
819
09-14-2023 07:19 PM
PierreloupDucroix
I created a floor-aware map in ArcGIS Pro using Indoors model, and I am able to select site, facility and level in the map.
However, once published in ArcGIS Online, the site and facility list does not appear, and I have the level list instead. The level selection is working fine.
Note that I only have one site and one facility.
Do you know what could be the issue ?
In Pro :
In Experience Builder Online :
CEO of MAGIS
GauravJobanputra
Hello @PierreloupDucroix what you see in ArcGIS Online is expected. The list will appear as soon as there are at least two (needs more than 1 - nothing to pick from if only 1). Note that the name of the Facility is available when you click Browse (Parcourir).
GauravJobanputra
PierreloupDucroix
thank you for the quick answer.
It works well with several sites and facilities.
Regards
CEO of MAGIS
emreaktas1
I am having trouble creating a ground aware map on arcgis pro. I cannot open the filter.
