ArcGIS Indoors Floor Selector in ArcGIS Dashboard or Experience Builder
2541
8
11-30-2023 05:10 PM
SamuelSong2
ArcGIS Indoors floor selector works in the standard Map Viewer but does anyone know if the floor selector works in ArcGIS Dashboard, Experience Builder or other apps? From my experience so far, it shows all the floors on top of one another with no option to select a floor or level.
I am trying to create some kind of Indoors app with data analytics such as interactive charts and tables.
Jinho_Kang
Is the floor-aware working now inside the Experience Builder?
Any layers that need to be toggled with the floor-widget have to be configured.
If you do have other layers like occupants or equipment, then yes.
Please have "LEVEL_ID" (and ideally/optional correct geometry-Z) configured under the Additional Layers tab to work.
Jinho_Kang
The floor-aware widget is available in the Experience Builder.
https://doc.arcgis.com/en/experience-builder/latest/configure-widgets/floor-filter-widget.htm
Load your floor-aware web map -> From the "Insert Widget" pane, drag and drop the "Floor Filter"on the map, and link with the map.
Example of CSULB's Experience Builder with floor filter.
https://experience.arcgis.com/experience/9c385c26672f42e39e21613fa4d560bb/
SamuelSong2
So I added the Floor filter widget in ArcGIS Experience Builder and linked the map per your suggestion (thank you!). It reads the building and floors but when I select the floor and zoom in, the visualization does not render or does not isolate the floors that was selected; all floors are overlapped. Not sure what I am doing wrong.
I ran the Import Floorplans To Indoors Geodatabase using the Excel template and the floor filter works fine on ArcGIS Pro.
Jinho_Kang
Hi Samuel.
Can you open up the source of the web map's property, and verify if the floor-aware configuration has all the layers?
SamuelSong2
Here is what I have. Floor aware works fine on the map layer. Do I need the other layers like Occupants, Equipment, etc.
Jinho_Kang
SamuelSong2
No, the floor filter widget is still not working in Experience Builder.
In order to troubleshoot further, I used a sample Esri Indoors data (IndoorsFPD) to create a floor aware Feature Layer and added the Floor Filter widget in Experience Builder and got the same issues. It identifies the floor labels but it does not cycle through all the floors when I selected them individually; not to mention space data are overlapped and blurry.
Could this be a bug?
Jinho_Kang
HI Samuel.
Can you make the source of the web map public and provide the link?
You can also email me with the link to jkang@esri.com if you rather not post the URL here.
SamuelSong2
Hello Jinho,
It was user error, I did not use Copy all data: Exploratory when creating the web map which created a map image instead of a feature layer. Thank you for all your help!
Sam
