I'm using latest version 3.2 of Deep Learning and I'm trying to find sample codes for training deep learning model on a single machine with multiple GPUs. I was told that multiple GPUs only works with arcgis.learn Python API. But I can't find a sample code to do this on a single machine setup. Most setup I found are for distributed parallel setup (multiple machines with GPUs).
Can anyone give me a link to sample codes or guides for this new feature in version 3.2 (multiple GPUs on single machine)?
Also, can I train the model using Jupyter Notebook in ArcGIS Pro? New to arcgis.learn so not sure where to go from here.
Appreciate any help.
I found the following links helpful:
1. To install ArcGIS API for Python: Install and set up | ArcGIS API for Python
2. To install deep learning libraries and backbones: arcgis_dl_backbones 2.0.1 - Overview
3. To train deep learning using multiple GPUs: Train arcgis.learn models on multiple GPUs | ArcGIS API for Python
I'm still experimenting but I think I'm on the right path.
Hi @JadedEarth ,
Could you please point me to the resources you mentioned for distributed parallel setup (multiple machines with GPUs)
