Can't add Landsat 9 to Raster Mosaic
1222
05-29-2024 10:53 AM
AhmedWagih
Hello, I downloaded Landsat 9 & 8 images off Earthexplorer, and tried to add them to a Raster Mosaic Dataset that I created using the Landsat 9 as Raster Type, and the projection system used by the images, however, I get the following message:
2024-05-29T20:45:18.888: Error: 8004818c: No new mosaic dataset item was added.
Without any further explanation. I tried even to load one single image, and got the same message. The images are being read properly into ArcGIS Pro 3.3 using their MTL file.
Any clues?
thanks
2 Solutions
JeffreySwain
When you add the Landsat Scene to Pro, what Raster Products are available?  Be sure when choosing the Landsat 9 image, you have selected one of the Raster Products that are within the scene.
Expand the Raster Properties when adding the raster.
Ed_
by MVP Regular Contributor
Earth Explorer usually downloads images in TIF format, can you make sure that the raster(s) is in tif format?
Question | Analyze | Visualize
JeffreySwain
AhmedWagih
Thanks Jeff for taking the time to reply (sorry for my late reply). I believe you're right, the second time when I used "Multiband" as a Processing Template, it did add some of the images (although not all, but that's probably due to an extent that I have set for my analysis).
Ed_
AhmedWagih
Thanks Ed for taking the time to reply. I did download the images in TIFF format.
