map in iframe in open data/hub page not functioning as expected
1605
10-10-2017 06:25 AM
GregMcNamee
New Contributor III
I'm a new to this so if I missed something obvious here, go easy on me.
I'm creating a page with with an ArcGIS Online Open Data site. The Layout Builder within the Page Editor allows you to add an iframe. I wanted to add a map of US State that was clickable. Initially I pointed it to a web map stored in AGO, using the share link. That worked fine. I wanted a bit more functionality than available in a simple web map. Specifically I wanted each state polygon to highlight on hover and when you click the state I wanted it to search the open data site by state name. So I pieced together the attached code using the JavaScript API and some tutorials. (I changed the search url to search google because my open data site is not shared publicly yet). The code seems to work. I hosted the html file on one of our servers, and it works fine. (But I can't share here because it's not in production). But it works, and is an exact copy of the code attached, except for the google part.
When I point iframe URL in the Settings of the Page Editor to the html file's url, nothing is displayed. It says specifically not to add the iframe code, but a url in the tutorial online. So my thought was to create an iframe in an html file that points to the map created by the attached code. Something like this:
<iframe width="100%" height="400" src="https://www.mysite.blah/OpenData/RegionSelectMap.html" frameborder="0">
</iframe>
I did that, but still nothing displays. Now I'm not sure what to do.
So how do I make the map I create in the attached file, show up in an iframe in an open data site page?
Any help would be appreciated.
Thanks.
Greg McNamee
GregMcNamee
New Contributor III
<!DOCTYPE html>
<html>
<head>
  <meta charset="utf-8">
  <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
  <title>Access features with pointer events - 4.5</title>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
    #info {
      visibility: hidden;
    .esri-popup__main-container {
      width: 225px !important;
  </style>
  <link rel="stylesheet" href="https://js.arcgis.com/4.5/esri/css/main.css">
  <script src="https://js.arcgis.com/4.5/"></script>
  <script>
    require(["esri/config"], function(esriConfig) {
    esriConfig.request.corsDetection = false;
    require([
      "esri/Map",
      "esri/views/MapView",
      "esri/layers/FeatureLayer",
      "dojo/domReady!"
    ], function(
      Map,
      MapView,
      FeatureLayer
      var layer = new FeatureLayer({
        url: "https://tigerweb.geo.census.gov/arcgis/rest/services/Generalized_ACS2015/State_County/MapServer/8",
        outFields: ["*"]
      var map = new Map({
        basemap: "streets",
        layers: [layer]
      var view = new MapView({
        container: "viewDiv",
        map: map,
        center: [-98, 32],
        zoom: 4
      layer.minScale = 0;
      //layer.maxScale = 0;
      view.ui.add("info", "top-right");
      // Set up an event handler for pointer-down (mobile)
      // and pointer-move events (mouse)
      // and retrieve the screen x, y coordinates
      view.on("pointer-move", eventHandler);
      view.on("pointer-down", eventHandler);
      view.on("click", function(event){
        view.hitTest(event)
          .then(function(response){
            var attributes = response.results[0].graphic.attributes;
            var sTerm = attributes.NAME;
            var url = "https://www.google.com/search?q="
            window.open(url+sTerm)
      function eventHandler(event) {
        // the hitTest() checks to see if any graphics in the view
        // intersect the given screen x, y coordinates
        view.hitTest(event)
          .then(getGraphics);
      function getGraphics(response) {
        // the topmost graphic from the click location
        // and display select attribute values from the
        // graphic to the user
        var graphic = response.results[0].graphic;
        var attributes = graphic.attributes;
        var rName = attributes.NAME;
        //document.getElementById("info").style.visibility = "visible";
        //document.getElementById("name").innerHTML = name;
        // symbolize all line segments with the given
        // storm name with the same symbol
        var renderer = {
          type: "unique-value", // autocasts as new UniqueValueRenderer()
          field: "NAME",
          defaultSymbol: layer.renderer.symbol || layer.renderer.defaultSymbol,
          uniqueValueInfos: [{
            value: rName,
            symbol: {
              type: "simple-fill", // autocasts as new SimpleLineSymbol()
              color: [ 128, 128, 128, 0.7 ],
              outline: {  // autocasts as new SimpleLineSymbol()
                color: [255, 255, 255, 0.5],
                width: 1
        view.popup.dockEnabled = true;
        view.popup.collapsed = true;
        view.popup.open({
          title: rName,
        layer.renderer = renderer;
      view.then(function() {
        layer.then(function() {
          // update the default renderer's
          // symbol when the layer loads
          var renderer = layer.renderer.clone();
          renderer.symbol.color = [128, 128, 128, 0.3];
          renderer.symbol.outline.color = [255, 255, 255, 0.5];
          renderer.symbol.outline.width = 1
  </script>
</head>
<body>
  <div id="viewDiv"></div>
  <div id="info">
  </div>
</body>
</html>
Greg McNamee
