jquery and bootstrap.min.js in Open Data Site
5948
10-16-2015 01:56 AM
deleted-user-bUSldQvlMRQ8
New Contributor II
I experience the following problem, with jQuery and bootstrap.min.js libraries in Footer of Open Data Site (to make the Bootstrap Carousel work):
1. On our (still experimental) Open Data Site Open data for Africa's Great Lakes Region I'm not able anymore to download the dataset (nothing happens by clicking the download button), but on the worldwide Portal the downlaod still works in all formats (Using Chrome and IE).
Using Firefox, even on the worldwide, the submenu on the download and API button is empty.
2. When I remove these libraries from the footer, Download and API buttons work again on Chrome and IE, but on Firefox the issue persists.
Probably the Firefox issue is not related to the jQuery/Boostrap.js issue.
Is there any chance that this conflict can be resolved, or do I have to remove my carousel?
Thx,
Annina
New Contributor II
At least I found the solution for the Firefox issue, definitely nothing to do with the jquery/bootstrap.js:
It was the firebug-extension. When disabling it, the search and download on the open data site works also with firefox.
For the moment, I removed the carousel from our Open Data Site, as there seems to be nobody you can confirm or answer that issue.
Katheryn_ZulayPeraza
Hello,
I have the same issue. When i  include in the Header HTML the next line code for enable the carousel :
<script src="https://maxcdn.bootstrapcdn.com/bootstrap/3.3.4/js/bootstrap.min.js"></script>
The download buttons on layers is disabled ( this occur in all web explorers)  .
So,Please,do you have some solution for solve it ? Daniel Fenton
Thanks in advance
I solve the issue :
1) Remove in the Header HTML the next line code for enable the carousel :
2) Include in the Header HTML the next script for enable the carousel without conflicts with the bootstrap included in Open Data Site:
<script>
* Bootstrap: carousel.js v3.3.6
* http://getbootstrap.com/javascript/#carousel
* Copyright 2011-2015 Twitter, Inc.
* Licensed under MIT (https://github.com/twbs/bootstrap/blob/master/LICENSE)
+function ($) {
  'use strict';
  // CAROUSEL CLASS DEFINITION
  var Carousel = function (element, options) {
    this.$element    = $(element)
    this.$indicators = this.$element.find('.carousel-indicators')
    this.options     = options
    this.paused      = null
    this.sliding     = null
    this.interval    = null
    this.$active     = null
    this.$items      = null
    this.options.keyboard && this.$element.on('keydown.bs.carousel', $.proxy(this.keydown, this))
    this.options.pause == 'hover' && !('ontouchstart' in document.documentElement) && this.$element
      .on('mouseenter.bs.carousel', $.proxy(this.pause, this))
      .on('mouseleave.bs.carousel', $.proxy(this.cycle, this))
  Carousel.VERSION  = '3.3.6'
  Carousel.TRANSITION_DURATION = 600
  Carousel.DEFAULTS = {
    interval: 5000,
    pause: 'hover',
    wrap: true,
    keyboard: true
  Carousel.prototype.keydown = function (e) {
    if (/input|textarea/i.test(e.target.tagName)) return
    switch (e.which) {
      case 37: this.prev(); break
      case 39: this.next(); break
      default: return
    e.preventDefault()
  Carousel.prototype.cycle = function (e) {
    e || (this.paused = false)
    this.interval && clearInterval(this.interval)
    this.options.interval
      && !this.paused
      && (this.interval = setInterval($.proxy(this.next, this), this.options.interval))
    return this
  Carousel.prototype.getItemIndex = function (item) {
    this.$items = item.parent().children('.item')
    return this.$items.index(item || this.$active)
  Carousel.prototype.getItemForDirection = function (direction, active) {
    var activeIndex = this.getItemIndex(active)
    var willWrap = (direction == 'prev' && activeIndex === 0)
                || (direction == 'next' && activeIndex == (this.$items.length - 1))
    if (willWrap && !this.options.wrap) return active
    var delta = direction == 'prev' ? -1 : 1
    var itemIndex = (activeIndex + delta) % this.$items.length
    return this.$items.eq(itemIndex)
  Carousel.prototype.to = function (pos) {
    var that        = this
    var activeIndex = this.getItemIndex(this.$active = this.$element.find('.item.active'))
    if (pos > (this.$items.length - 1) || pos < 0) return
    if (this.sliding)       return this.$element.one('slid.bs.carousel', function () { that.to(pos) }) // yes, "slid"
    if (activeIndex == pos) return this.pause().cycle()
    return this.slide(pos > activeIndex ? 'next' : 'prev', this.$items.eq(pos))
  Carousel.prototype.pause = function (e) {
    e || (this.paused = true)
    if (this.$element.find('.next, .prev').length && $.support.transition) {
      this.$element.trigger($.support.transition.end)
      this.cycle(true)
    this.interval = clearInterval(this.interval)
    return this
  Carousel.prototype.next = function () {
    return this.slide('next')
  Carousel.prototype.prev = function () {
    return this.slide('prev')
  Carousel.prototype.slide = function (type, next) {
    var $active   = this.$element.find('.item.active')
    var $next     = next || this.getItemForDirection(type, $active)
    var isCycling = this.interval
    var direction = type == 'next' ? 'left' : 'right'
    var that      = this
    if ($next.hasClass('active')) return (this.sliding = false)
    var relatedTarget = $next[0]
    var slideEvent = $.Event('slide.bs.carousel', {
      relatedTarget: relatedTarget,
      direction: direction
    this.$element.trigger(slideEvent)
    if (slideEvent.isDefaultPrevented()) return
    this.sliding = true
    isCycling && this.pause()
    if (this.$indicators.length) {
      this.$indicators.find('.active').removeClass('active')
      var $nextIndicator = $(this.$indicators.children()[this.getItemIndex($next)])
      $nextIndicator && $nextIndicator.addClass('active')
    var slidEvent = $.Event('slid.bs.carousel', { relatedTarget: relatedTarget, direction: direction }) // yes, "slid"
    if ($.support.transition && this.$element.hasClass('slide')) {
      $next.addClass(type)
      $next[0].offsetWidth // force reflow
      $active.addClass(direction)
      $next.addClass(direction)
      $active
        .one('bsTransitionEnd', function () {
          $next.removeClass([type, direction].join(' ')).addClass('active')
          $active.removeClass(['active', direction].join(' '))
          that.sliding = false
          setTimeout(function () {
            that.$element.trigger(slidEvent)
          }, 0)
        .emulateTransitionEnd(Carousel.TRANSITION_DURATION)
    } else {
      $active.removeClass('active')
      $next.addClass('active')
      this.$element.trigger(slidEvent)
    isCycling && this.cycle()
    return this
  // CAROUSEL PLUGIN DEFINITION
  function Plugin(option) {
    return this.each(function () {
      var $this   = $(this)
      var data    = $this.data('bs.carousel')
      var options = $.extend({}, Carousel.DEFAULTS, $this.data(), typeof option == 'object' && option)
      var action  = typeof option == 'string' ? option : options.slide
      if (!data) $this.data('bs.carousel', (data = new Carousel(this, options)))
      if (typeof option == 'number') data.to(option)
      else if (action) data[action]()
      else if (options.interval) data.pause().cycle()
  var old = $.fn.carousel
  $.fn.carousel             = Plugin
  $.fn.carousel.Constructor = Carousel
  // CAROUSEL NO CONFLICT
  $.fn.carousel.noConflict = function () {
    $.fn.carousel = old
    return this
  // CAROUSEL DATA-API
  var clickHandler = function (e) {
    var href
    var $this   = $(this)
    var $target = $($this.attr('data-target') || (href = $this.attr('href')) && href.replace(/.*(?=#[^\s]+$)/, '')) // strip for ie7
    if (!$target.hasClass('carousel')) return
    var options = $.extend({}, $target.data(), $this.data())
    var slideIndex = $this.attr('data-slide-to')
    if (slideIndex) options.interval = false
    Plugin.call($target, options)
    if (slideIndex) {
      $target.data('bs.carousel').to(slideIndex)
    e.preventDefault()
  $(document)
    .on('click.bs.carousel.data-api', '[data-slide]', clickHandler)
    .on('click.bs.carousel.data-api', '[data-slide-to]', clickHandler)
  $(window).on('load', function () {
    $('[data-ride="carousel"]').each(function () {
      var $carousel = $(this)
      Plugin.call($carousel, $carousel.data())
}(jQuery);
</script>
by Anonymous User
Not applicable
Hey Katheryn!
I'm having trouble integrating a simple carousel into my OD site. I've added a text-element into its place in a row, but whenever I get a sample working in jfiddle or something, the OD site just show it as a list with no dynamism (photo attached).
Could you expand on how to get a working carousel into the OD site?
