Is there a way to pull apps hosted in Portal into HUB?
718
06-02-2023 06:41 AM
Sarah_of_Lubbock
Is there a way to pull apps in Portal into Hub?
On AGOL - we have public apps and a few internal apps (the ArcGIS solutions), and on Portal, just internal apps.
I wanted to make a single place that everyone can go to access the apps that they need (based on groups so you can only see what is pertinent to you).  But I can't find a way to pull the Portal data over.
I mostly just want to avoid the situation where an internal person has apps they need on both AGOL and Portal and having to remember where to go - and to remember there are public apps that might also be beneficial to them.
Any ideas?  Thanks!!!
JonathanMcD
Check out Distributed Collaboration between AGOL and Portal, that'll bring your data through.
Sarah_of_Lubbock
I do have collab data running between the two - but none of my apps would go over - but to get around that - I forgot you can make an item on AGOL with a URL - so I did that - and now I can pull all my Portal apps into Hub!
