Hub Application Item Open in New Tab
97
06-29-2022 11:51 AM
KansasDASC
New Contributor II
We have a number of applications that are discoverable in our Hub site. There is one item that has a symbol next to it in the search results that when clicked, opens the application in a new tab, outside of Hub.
Then there's other applications that don't have this symbol and when clicked, opens the application as a Hub item showing the application, but surrounded by the Hub application.
How do I add or remove this symbol/ability, so that all applications open external to the Hub, or remove it so that all applications can open inside of the Hub?
versus...
KlaraSchmitt
@KansasDASC ,
In your site editor, go to Settings > Interactions and enable the Embedded Apps toggle. This will keep applications opening under your site header and the links in search results should not display the "opens external link / new tab" symbol.
KansasDASC
New Contributor II
Hi @KlaraSchmitt we already had the Embedded Apps toggled to on and as a test, I toggled it off, then back on, saved then draft, then published, and there was no change with the issue.
KlaraSchmitt
Hello @KansasDASC ,
Hmm. I'm not sure then. It seems like it could be a bug; unfortunately, I am not super knowledgable when it comes to issues in the search catalog. Have you tried reaching out to Support to see if they can assist?
KansasDASC
New Contributor II
Not yet, I was hoping this was something that I overlooked in the settings at the AGOL item level or configuration within Hub.
