When we make our Open Data site public this week I noticed a problem with the dates associated with each entry. Most are displaying 4/1/2018 which is off by a couple of weeks. Another entry, shown in the attached file, is off by almost a year showing a 4/23/2017 date even though the data was registered only last month. Basically, they are all wrong in Open Data but all correct in AGOL
Where does this Open Data date come from?
Here's our work flow:
Last night I updated all 8 layers in SDE doing a truncate append and reloaded the metadata in AGOL. This updated the date in AGOL showing yesterday's date but has had no affect on the date shown in Open Data.
Solved! Go to Solution.
Thanks for replying on this thread, Mark. Hopefully I can provide some clarification about how dates work in Hub.
There are 3 places Hub looks when writing the "Last Updated" date. If an admin has explicitly set a publication date in the metadata editor in ArcGIS Online, we will use that date. If not, then depending on whichever was updated more recently we will use either a) the last time the item was edited or “touched” in ArcGIS Online or b) the last time an update was made to the service (if editor tracking is enabled).
You can test this on sites with the new search enabled (e.g. https://hub.arcgis.com/search) by hovering over the date field in search. If the tooltip reads “Last updated” then it’s coming from the publication date in the metadata editor. If it reads “Metadata updated” then the date is coming from the last time the item was edited in ArcGIS Online. If it reads “Data updated” then the date is coming directly from the service.
We found the same thing, Open Data appears to use the metadata dates rather than the ArcGIS Online last updated dates https://community.esri.com/thread/222598-inconsistency-between-open-data-and-items-views
Looks like it's coded to check for Publication and Revision date in the metadata. I removed the Publication date from our metadata, so it would get an update date representing the last time the service was updated (via script) but it wasn't updating, instead it was showing the Revision date:
Metadata:
Open Data item:
