ArcGIS Hub Category Card not showing tagged data
810
02-28-2020 08:04 AM
MargaretStead
New Contributor II
i have an open data site with a category card set to "use tag query".  The tag query is "huntsvillle governance".
The data table layer I have shared has the tag "huntsville governance", but the data table does not show up when users click on the Category Card.  Any suggestions ?
Tags (1)
GeorgiaCummins
New Contributor III
I am having the same issues, but have not figured it out just yet.
by Anonymous User
Not applicable
I'm having the same issue. Even if I enter the same tags into feature layers and category cards, the feature layers don't occur in category cards.  Any guidance from Esri fellows would be much appreciated!
MatthewBeal
Occasional Contributor III
Did you ever figure this out? I am having this same issue now.
JackNessen2
Having the same issue. Building a GeoHub fthat contains a data section with 6 category cards set to category query. Only one category is working, but only showing 8 datasets of the total 11 tagged.
NathanPugh2
I'm having the same problem.  My categories don't return any results.  Has anyone been able to solve this issue or identify the cause?
