API Error Open Data Download
12787
45
06-09-2021 11:01 AM
Tony_J_Van_Der_Wielen
We started seeing and API error in the download section of our Open Data page. It looks like there are no reported issues on Esri's end https://status.arcgis.com/.
Has anyone seen this? Or do you know how to fix it? This is happening with all our content.
Thank you!
Tony
MeghanLeavey
Thank you for all of your help!
StanislausCounty
We are still experiencing the issue. I do see in the changelog that it has been fixed; has it been pushed out yet or is there still some problem?
John_Spence
It cleared up for us, but we were also dropped the original feature service and rebuilt it from the ground up.  Not a pleasant experience, but it let us get the issue resolved.
ThomasHervey1
Sorry to see that you're still having an issue. Is this the site where you're having issues https://open-data-stancounty-gis.hub.arcgis.com/ ?
I have reproduced the issue and I've marked a fix has high priority.  In the meantime, I suggest that you try making those items private and then public again. Afterward you may need to remove the link and re-add them within the gallery cards.
The problem comes from the fact that these those gallery cards link out to items referencing services that have multiple layers. The update is still tying to reference the original URL without knowledge that this is a layer. For example, if you click the Annexations gallery card link, you'll route to https://open-data-stancounty-gis.hub.arcgis.com/datasets/d32e342982c849839aa787a1ae513f15_8/explore?...
instead users should be route to a slightly different URL
We recognize that these bugs are very impactful and that the routing is confusing. Near-term we are adding additional tests to ensure that routing changes do not affect downloads. Mid-term we have plans to simplify the routing logic and remove the confusing _:layerId portion of the URL.
StanislausCounty
Hi Tom,
Yes, that is the site we are having trouble with. I'll try making them private and then public; with respect to the gallery cards, this was generated via the dynamic gallery layout. I'm assuming that removing it and re-adding it would generate the URLs again so I'll also give that a shot as well. We do appreciate your help!
ThomasHervey1
Thanks for the details. Please let me know if that doesn't work. We should have a fix ready by tomorrow and optimally released tomorrow as well.
StanislausCounty
Hi Tom, we tried making the layers private and then public and then re-adding the gallery to the page but it doesn't appear to be working.
Todd_Metzler
Same.  First reported to us 2021-09-09.  1st stop was AGOL Health Dashboard .  All green still green.  We've opened our own case with Esri tech support.
John_Spence
We got past it by republishing the dataset.
Todd_Metzler
Good to know there is another workaround.  Not practicable for our enterprise.  We have hundreds of services and over 30 publishers.
