We have a large dataset that was being hosted on ArcGIS Online, we moved it to ArcGIS Enterprise as a hosted feature layer in order to save credits. Ever since we have done this, our ArcGIS Monitor has been sending us emails about high utilization of our Data Store server. Looking at our web server logs, I have identified that the traffic is coming from the HUB indexer. As this is a static dataset, it does not make sense for HUB to be indexing it every day. It would be great to have the ability to mark a layer as static so the indexing does not occur. I thought this used to be possible in older version of HUB/Open Data. Also if HUB could check the last edit date prior to doing the indexing to see if there have been any edits made.
Definitely considering this already. Thanks for reaching out
