In this third and final installment of our blog series, we’ll explore how to improve search engine optimization (SEO) and discoverability across multiple domains in ArcGIS Hub. From metadata management to social sharing previews, small tweaks can have a big impact on how your content is indexed and shared.
The first step to improving visibility is making sure your content is easy for search engines to understand. ArcGIS Hub gives you control over several key pieces of metadata.
Good Example:
Visual cues help your site stand out. This is especially true when shared on social platforms. Be sure to upload a high-quality thumbnail image that represents the site’s content or brand.
While ArcGIS Hub doesn’t let you configure Open Graph tags directly, it does automatically generate them using your:
This metadata controls how your site appears in platforms like Facebook, Twitter, and LinkedIn. To influence this:
ArcGIS Hub automatically generates a sitemap.xml file for each site. This is a roadmap that search engines use to crawl your site efficiently.
Best Practices:
As your Hub ecosystem grows, so does the risk of duplicate or hard-to-find content. Here are a few traps to avoid:
Don’t copy and paste the same content to multiple Hub sites. This can confuse search engines and dilute your rankings.
Do this instead: Create one canonical source and link to it from other sites.
Avoid cryptic URLs or mismatched branding between pages. Consistency helps both users and search engines navigate your domain ecosystem.
If you change a site’s name or domain, set up redirects to prevent link rot. This is especially for pages that are already indexed or shared publicly.
There are a few free tools that can help you audit and enhance discoverability:
Use these to test load speed, metadata, and mobile responsiveness - all of which affect your SEO ranking.
Your ArcGIS Hub sites are only as valuable as they are discoverable. By taking a few intentional steps from optimizing metadata to testing how your sites show up in search, you’ll ensure your work reaches the audience it’s intended for.
We hope you enjoyed this series!
