Geostats Extension - Possible to use a Input Barrier Polyline or Polygon for Kriging
96
09-22-2020 11:54 AM
Hello,
I am trying to find out if there is a way to specify an input barrier line or input barrier polygon Feature Class when performing interpolation?  Specifically I am using the Empirical Bayesian Kriging 3d interpolation method and would like to specify a barrier to limit kriging.  Thanks.
Cheers,
Blair
Reply
Hi Blair,
A barrier in geostatistics usually means a line where the values of variables change instantly.  Fault lines, cliffs, and shorelines are common barriers.  Unfortunately, Empirical Bayesian Kriging 3D does not allow barriers of this kind; the model assumes that the values change gradually without any discontinuities.  Two interpolation methods, Kernel Interpolation With Barriers and Diffusion Interpolation With Barriers, allow barriers to be used, but they are both 2D interpolation methods.
-Eric
Hi Blair,
-Eric
Thank you for the quick reply Eric Krause
Reply
