I am performing Gaussian geostatistical simulation (conditional). But, the mean and minimum output rasters have some negative values. Some simulated maps have negative values. Does anybody have some idea why this is happening? Could it mean that my ajuste
1447
01-05-2017 11:29 AM
CarineSilva
I am performing Gaussian geostatistical simulation (conditional). But, the mean and minimum output rasters have some negative values. Some simulated maps have negative values. Does anybody have some idea why this is happening? Could it mean that my ajusted model in the simple kriging is not good? Thanks.
DanPatterson_Retired
Gaussian Geostatistical Simulations—Help | ArcGIS Desktop and
How Gaussian Geostatistical Simulations works—Help | ArcGIS Desktop
makes no mention of equating negative values as being bad... perhaps you could comment on what you found by examining your results.
EricKrause
It is simulating from a Gaussian distribution, and negative values are valid simulations from this model.  The phenomenon that you are interpolating may not be able to be negative (like rainfall or pollution levels), but the model doesn't know this, and some of the simulations will likely contain negative values just due to chance.
I only know one way to guarantee that all simulated values will be greater than zero, but it requires changing your simple kriging geostatistical layer.  In the Geostatistical Wizard, make sure that you are using simple kriging, and use a Normal Score Transformation.  On the transformation page (with the histogram on the left), choose Lognormal, Gamma, or Log Empirical for the Base distribution (found on the right).  To use these options, all your data values must be greater than zero, but these options will guarantee that all predictions and simulations will also be greater than zero.
