HTML report in Local Moran's I
1033
03-26-2021 01:16 PM
mchandra18
I ran Local MOran's I in ARCMAP but I cannot find the HTML report in Local Moran's I result panel. Please advise how to fix this problem
Monalisa
DanPatterson
MVP Esteemed Contributor
Spatial Autocorrelation (Global Moran's I) (Spatial Statistics)—ArcGIS Pro | Documentation  for ArcGIS Pro, check the arcmap equivalent help
arcpy.stats.SpatialAutocorrelation(Input_Feature_Class, Input_Field, {Generate_Report}, Conceptualization_of_Spatial_Relationships, Distance_Method, Standardization, {Distance_Band_or_Threshold_Distance}, {Weights_Matrix_File}, {number_of_neighbors})
Generate_Report
(Optional)
NO_REPORT —No graphical summary will be created. This is the default.
GENERATE_REPORT —A graphical summary will be created as an HTML file.
... sort of retired...
