Web Socket does not work with https upon using StreamServer
3245
10
11-08-2016 01:45 AM
MiriEshel
New Contributor III
I have a StreamService that works fine when ArcGIS Server is configuted with HTTP.
When I change it to HTTPS,  it gives an error.
Upon Subscribe:
A web socket connection to the stream service running at https://mirie-pc.stltd.co.il/arcgis/rest/services/cars_Feed/StreamServer could not be established. Please inform the GIS Administrator.
Upon watching service in JavaScript:
Stream service url: https://mirie-pc.stltd.co.il/arcgis/rest/services/cars_Feed/StreamServer
The Firewall is turned off. My browser supports WebSocket.
How do I fix this problem? It is urgent....
Thanks a lot,
Miri
Tags (1)
Reply
MarkBramer
Occasional Contributor II
Are all your SSL certificates fully valid and in place?  Can you navigate to https://mirie-pc.stltd.co.il/arcgis/rest/services/cars_Feed/StreamServer in a browser without any secure connection warnings, and get a 'green' notification (i.e. padlock, green 'http:', etc) that everything is good?
Reply
MichalGrinvald
Yes All the SSL certificates are fully valid and in place:
Reply
AlexanderBrown5
Michal,
Go to your url for your stream service: https://mirie-pc.stltd.co.il/arcgis/rest/services/cars_Feed/StreamServer
At the bottom where it says Web Socket URLs, copy "ws://yourserver:6180" -- I assume "ws://mirie-pc.stltd.co.il:6180."
Depending on your security method (https only or http/https), you might have to grab "wss://" or "ws://". I would try "ws://" first.
Log into your arcgis server admin https://hostname:6443/arcgis/admin  -- https://mirie-pc.stltd.co.il:6443/arcgis/admin
Go to System-> Properties
Update your server properties with this format:
{"WebSocketContextURL": "ws://yourserver:6180"}
or if the url is correct from above:
{"WebSocketContextURL": "ws://mirie-pc.stltd.co.il:6180"}
Hit update.
Let me know if that works for you, I had a similar issue on an amazon server and that fixed it for me.
~Alex
MiriEshel
New Contributor III
Hi Alex,
Thank you for your reply. I tried it but it did not work. I think it is because it works fine with http, only https causes problems.
So I tried {"WebSocketContextURL": "wss://yourserver:6143"} but that did not help either.
My client has a problem also with http so I'll try it there and let you know.
Miri
Reply
AlexanderBrown5
Miri,
Did you ever resolve your issue?
~Alex
Reply
WillHughes2
New Contributor III
Any resolution for HTTPS? Thank you.
Reply
AlexanderBrown5
Will,
I have successfully implemented this using HTTPS in amazon.
{"WebSocketContextURL": "wss://negeoevt.esri.com:6143"}
I have also helped a few organizations to get HTTPS to work.  It is usually related to a firewall rule that is blocking TCP 6143.
Give me a call if you want to discuss.
~Alex
Reply
ADPOPEELAADPOPEELA
HI Alex,
I faced the same problem and couldn't rectify the problem. Tried to update the websocketcontexturl using both ports. Was there anything else you have done to solve it aside from the update in the arcgis server admin > System > properties > update?
Michael
Reply
IainGoodridge
New Contributor II
Hi Alex, I have ran into a similar issue, I wondered if you could share a little more on some fixes for AWS and the websocket.
Reply
