Im going to attach the finished code I used that works with ESRI's twitter sample:<!doctype html>
<html>
<head>
<meta charset="utf-8">
<meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
<title>StreamLayer using ArcGIS API for JavaScript and ArcGIS GeoEvent Processor for Server</title>
<link rel="stylesheet" href="http://js.arcgis.com/3.8/js/dojo/dijit/themes/tundra/tundra.css">
<link rel="stylesheet" href="http://js.arcgis.com/3.8/js/esri/css/esri.css">
<style type="text/css">
html, body {
height: 100%; width: 100%;
margin: 0; padding: 0;
body{
background-color: #fff; overflow:hidden;
font-family: sans-serif;
#map {
width: 100%;
height: 80%;
</style>
<script src="http://js.arcgis.com/3.8/"></script>
</head>
<body class="tundra">
<div id="map"></div>
<div>
<span>Enter websocket connection: </span><input type="text" id="txtWsUrl" value="ws://localhost.esri.com:6180/StreamService" style="width: 400px"/><br/>
<input type="button" id="cmdNewStream" value="Make Stream Layer" />
<input type="button" id="cmdDisconnect" value="Disconnect Stream Layer" />
</div>
</body>
<script>
var curTime = new Date();
var curTimeStamp = Date.parse(curTime.toUTCString());
var layerDefinition = {
"geometryType": "esriGeometryPoint",
"timeInfo": {
"startTimeField": "created_at",
"endTimeField": null,
"trackIdField": "id_str",
"timeReference": null,
"timeInterval": 1,
"timeIntervalUnits": "esriTimeUnitsSeconds",
"exportOptions": {
"useTime": true,
"timeDataCumulative": false,
"timeOffset": null,
"timeOffsetUnits": null
"hasLiveData": true
"fields": [
type: "esriFieldTypeString",
alias: "text"
type: "esriFieldTypeDate",
alias: "created at"
type: "esriFieldTypeInteger",
alias: "retweet count"
alias: "id_str"
var map, featureCollection, streamLayer;
require(["esri/map",
"esri/TimeExtent",
"esri/layers/StreamLayer",
"esri/InfoTemplate",
"esri/symbols/SimpleMarkerSymbol",
"esri/symbols/SimpleLineSymbol",
"esri/renderers/SimpleRenderer",
"esri/renderers/TimeClassBreaksAger",
"esri/renderers/TemporalRenderer",
"dojo/_base/Color",
"dojo/dom",
"dojo/on",
"dojo/domReady!"
], function(Map, TimeExtent, StreamLayer, InfoTemplate, SimpleMarkerSymbol, SimpleLineSymbol, SimpleRenderer, TimeClassBreaksAger, TemporalRenderer, Color, dom, on){
var trackedBusses = {}, cnt = 0;
map = new Map("map",{
basemap: "gray",
center: [-96, 36.428],
zoom: 4
// event listeners for button clicks
on(dom.byId("cmdNewStream"), "click", makeNewStreamLayer);
on(dom.byId("cmdDisconnect"), "click", disconnectStreamLayer);
function makeStreamLayer(){
//Make FeatureCollection to define layer without using url
featureCollection = {
"layerDefinition": null,
"featureSet": {
"features": [],
"geometryType": "esriGeometryPoint"}
featureCollection.layerDefinition = layerDefinition;
// Instantiate StreamLayer
// 1. socketUrl is the url to the GeoEvent Processor web socket.
// 2. purgeOptions.displayCount is the maximum number of features the
// layer will display at one time
// 3. trackIdField is the name of the field that groups features
var layer = new StreamLayer(featureCollection, {
socketUrl: txtWsUrl.value,
purgeOptions: { displayCount: 500 },
trackIdField: featureCollection.layerDefinition.timeInfo.trackIdField,
infoTemplate: new InfoTemplate("tweet: ${text}", "Timestamp: ${created_at}" )
console.log("TrackID: ", featureCollection.layerDefinition.timeInfo.trackIdField);
console.log("TrackID: ", layer.timeInfo.trackIdField);
//Make renderer and apply it to StreamLayer
var renderer = makeRenderer();
layer.setRenderer( renderer );
//Subscribe to onMessage event of StreamLayer so can adjust map time
layer.on("message", processMessage);
return layer;
// Process message that StreamLayer received.
function processMessage(message){
if (featureCollection.layerDefinition.timeInfo &&
featureCollection.layerDefinition.timeInfo.startTimeField) {
var timestamp = message[0].attributes[featureCollection.layerDefinition.timeInfo.startTimeField];
if (! map.timeExtent){
map.setTimeExtent(new esri.TimeExtent(new Date(timestamp), new Date(timestamp)));
console.log("TIME EXTENT: ", map.timeExtent);
} else {
var tsEnd = Date.parse(map.timeExtent.endTime.toString());
if (timestamp > tsEnd){
map.setTimeExtent(new esri.TimeExtent(map.timeExtent.startTime, new Date(timestamp)));
// Make new StreamLayer and add it to map.
function makeNewStreamLayer(){
disconnectStreamLayer();
streamLayer = makeStreamLayer();
map.addLayer( streamLayer );
// Disconnect StreamLayer from websocket and remove it from the map
function disconnectStreamLayer(){
if (streamLayer){
streamLayer.suspend();
streamLayer.disconnect();
streamLayer.clear();
map.removeLayer(streamLayer);
streamLayer = null;
//map.timeExtent = null;
// Make temporal renderer with latest observation renderer
function makeRenderer(){
var obsRenderer = new SimpleRenderer(
new SimpleMarkerSymbol("circle", 8,
new SimpleLineSymbol("solid",
new Color( [5, 112, 176, 0] ), 1),
new Color( [5, 112, 176, 0.4] )
var latestObsRenderer = new SimpleRenderer(
new SimpleMarkerSymbol("circle", 12,
new Color( [5, 112, 176] )
var temporalRenderer = new TemporalRenderer(obsRenderer, latestObsRenderer, null, null);
return temporalRenderer;
</script>
</html>
JP
