Trying to "field map" a one to many join, am I using the right Processor?
465
12-01-2017 02:12 PM
CM1
I am trying to set up a simple GeoEvent Service to essentially monitor a field on one feature service and then update all instances of another feature service's field (which has duplicate features of the first feature service).
I have attached a screenshot of a schema example below (I have not shown the Geometry field because my goal is to only update attribute information not geometry):
But when I setup a GeoEvent Service with:
Input Connector Feature 1  ----> Field Mapper Set with UID as join -----> Output Update Feature 2
I get something more like this:
Whereas I was expecting to have each STATUS from Feature 1 map via the UID to each UID (one to many) of Feature 2 and populate all STATUS fields.  This sort of makes sense though I guess as perhaps the UID from Feature 1 is only mapping to the first unique UID in Feature 2?
Any thought on a different approach I should be taking to get the desired outcome?
Thank you.
JeremyNicoletti1
I'm new to GeoEvent Server and having the exact same problem you are having. Maybe I can bump this for an answer for posterity?
