Mark,
I was able to successfully setup a synchronization rule that imports two geofences from the service published using the map package file you shared with us. Here are the two geofences in json format I see available on my 10.2.0 instance of GeoEvent processor:
[{"category":"PTZ","name":"CAM2","active":true,"subscriptionID":1,"geometries":[{"value":{"rings":[[[-50.80078124954654,-26.194876675510773,0.0],[-33.92578124987433,-26.980828590149343,0.0],[-32.51953125012625,-41.31082388091937,0.0],[-51.503906249869736,-42.48830197980847,0.0],[-50.80078124954654,-26.194876675510773,0.0]]],"spatialReference":{"wkid":4326}}}]},{"category":"PTZ","name":"CAM3","active":true,"subscriptionID":1,"geometries":[{"value":{"rings":[[[-58.18359375024528,-23.26153416780188,0.0],[-67.1484375003238,-37.45741810237051,0.0],[-85.60546875027406,-39.65645604818096,0.0],[-87.01171875002215,-24.547123179650182,0.0],[-58.18359375024528,-23.26153416780188,0.0]]],"spatialReference":{"wkid":4326}}}]}]
So far everything works as expected.
Now, let me try to put together the rest of the puzzle. If you want me to use the same data as you use for generating Alerts may I ask you a favor to send me another map package to work with. Otherwise I will setup a sample dataset according to the schema you shared with me in the different thread as follows:
Alerts
�?� CREATED
�?� MESSAGE
�?� PRIORITY
I would also like to verify the schema of your GeoFence layer. According to the other thread it should look like this:
Geo Fence layer
�?� AreaID
�?� Region
�?� ManagerName
According to the map package you already shared with us this layer has a little different schema. Can you do me a favor and verify that data I am using matches yours.
My plan is to send you the configuration and ask you to import it into your server environment and verify after I fully complete deploying your scenario to my box here.
Please let me know.
Vlad.
