Is There An Updated Route Monitor Add-In For Operations Dashboard Available?
878
08-08-2013 11:40 AM
JithenSingh
Hi There,
Is there an updated Route Monitor add-in for Operations Dashboard available? I see the current one is for EAP2.
I seem to be having issues create geofences from the widget and was wondering if this could be related to the version.
Thanks
MingZhao
New Contributor III
We are working on an update to the Route Monitor.  However, your GeoFence issue is likely not related to this upgrade.  In other words, we are able to add Geofences with no changes to the old Route Monitor.  I am attaching the configuration for the widget.  See if it resolves your problem.
[ATTACH=CONFIG]26603[/ATTACH]
JithenSingh
Thanks. Good to know. I have it all working now.
