com.esri.ges.messaging.jms.destinationPolicy.queue.memoryLimit=100 mb com.esri.ges.messaging.jms.destinationPolicy.topic.memoryLimit=100 mb com.esri.ges.messaging.jms.systemUsage.memoryUsage.limit=128 mb com.esri.ges.messaging.jms.systemUsage.storeUsage.limit=100 gb com.esri.ges.messaging.jms.systemUsage.tempUsage.limit=10 gb com.esri.ges.messaging.jms.brokerNamed=192.168.110.111 com.esri.ges.messaging.jms.dataDirectory=\\chenjun\data\activemq\localhost com.esri.ges.messaging.jms.kahadbDirectory=\\chenjun\data\activemq\localhost\kahadb com.esri.ges.messaging.jms.openwire.uri=tcp://localhost:61616 com.esri.ges.messaging.jms.stomp.uri=stomp://localhost:61613
Hello Chen -
I'd like to make sure that I understand your question. Are you working with a single data stream and need advice on how to manually configure a cluster of GeoEvent Processor instances which will work collectively to pull and processing individual events from the high volume data being received? Support for high-availability and clustering are concepts being developed for the "11" product release which will feature a new type of stream service input. We are working to make this functionality available later this year.
It may be possible to manually configure high-availability and clustering for the current 10.2.1 product release - but it depends on what exactly you are trying to accomplish.
If you are working with several different (independent) data feeds, you can scale your site architecture by installing additional instances of GeoEvent Processor onto the GIS Servers in your ArcGIS for Server site. You would simply need to make sure that each instance of GeoEvent Processor had its own Inputs, Outputs, and GeoEvent Services.
- RJ
Hello all,
Do you have some documentation for correct installation and set up to Geoevent in ArcGIS Server cluster?
All machines are in the same cluster in ArcGIS server and are running and have geoevent extension installed, but when any machine try to start the geovenet manager ( https://localhost:6443/geoevent/manager), the display show this message: No services have been found.
Thanks in advance
