Geoevent not start after update 10.5.1 version
2890
10
07-07-2017 07:58 AM
Javier_Pintos
I have installed Geoevent 10.5 and make a update to 10.5.1. After install (and testing some times) I have an error 404:
HTTP ERROR: 404
Problem accessing /geoevent/goto-manager. Reason:
Not Found
Powered by Jetty://
Someone, can help me?
PD: I attach karaf.log.
Thank.
Javier
Javier_Pintos
Hi James,
I was resolve this issue enabling http://repo1.maven.org/maven2 in the proxy. After install, Geoevent try download or update some depencencies.
Best regard.
Javier
Javier_Pintos
Hello dears,
Someone can help me?
I think, I will back to 10.5 version.
JamesCameron1
I had the same issue. I managed to get a bug raised via our country vendor..
BUG-000106503
Javier_Pintos
Hi James,
Best regard.
Javier
ANANDC
Hi Javier, Can you help me to fix this, i got the same issue, but no solutions.
Javier_Pintos
Hello ANAND,
I fixed this issue adding ip address of "http://repo1.maven.org/maven2" in hosts file of windows, because my error say that don't find this repository. Another alternative is configure a proxy gateway in ArcGIS Server Account of windows.
But, can you give more details about your issue??? Do you have karaf.log file???
Regard.
Javier Pintos
Ciampagna & Asoc.
ANANDC
Thanks Javier for your quick response.
I have dropped the files in drive
GeoEvent Server Log - Google Drive
I have some error notification in wrapper.log
ANANDC
This issue was fixed. Got some bundle files from esri inc , one of my colleague helped me with this.
kishanchintala
I am getting same error Geoevent server 10.5.1 http error 404 problem accessing/geoevent/goto-manager
so what kind bundle files could you attach files and procedure
ChrisBeyett
For anyone else who notices this behavior, there is now a 10.5.1 Patch that addresses this problem:
ArcGIS GeoEvent Server 10.5.1 Patch 1
- Chris
