Cannot Register an ArcGIS Server in GeoEvent Manager
1596
6
11-27-2017 06:40 AM
NicoKroes1
Hello Everyone:
I am currently experiencing an issue with Registering an ArcGIS Server with GeoEvent Manager in the "Data Stores" menu. Whenever I attempt to register an ArcGIS server, a red icon appears in the status field (See Image Below).
For reference, Below are the values that I have populated for the "Edit ArcGIS Server" window.
Does anyone know why the ArcGIS Server cannot be registered with GeoEvent Server? Please let me know if I can provide any details that might help.
Nico
NicoKroes1
I figured it out. I needed to use token based authentication (see number 1 in the image). I first generated a token on the server that I wanted to register.  Next, I entered the token that was generated from the server (see number 2 in the image). After that, the server was successfully registered. I appreciate your help!  crodriguezesri-co-esridist‌.
Nico
Cesar_AugustoRodriguez
Hi! Niko Kroes
Can you try to register in a new register your ArcGIS Server into the data store using your server URL?
It should be similar to "https://Yourservername:6443/arcgis" if you have a web adaptor it should be similar to "https://Yourservername/YourPortalWebAdaptor"
Please remember, if you before has been federated your arcgis server with your portal for ArcGIS (Base deployment ArcGIS Enterprise) you should register it with your portal account.
NicoKroes1
Unfortunately, I was not able to register the server after entering my server information in the format that was specified above. The "My Server" item below is what I wanted to register. What else do I need to do?
Nico Kroes
What kind of message show when you are on status logo? Do you need check the credentials provided?
Can you try to check "Use credentials"?
NicoKroes1
Cesar:
I am getting a "Token Required" message when I hover over the red error icon that you hovered over.
Nico
NicoKroes1
Nico
Hi Nico
Where do you get your token? Do you get it from ArcGIS Server's Admin? Please, You take in mind that if you go to create a token needs User name and Password.
Managing data stores—Real-Time Data Feeds and Sensors (10.5.1) | ArcGIS Enterprise
Acquiring ArcGIS tokens—ArcGIS Server Administration (Windows) | ArcGIS Enterprise
Regards
