Are there particular settings at the IIS level for the Geoevent?
1877
5
08-29-2014 06:04 AM
JamalNUMAN
Legendary Contributor
As the Geoevent is communicated via https instead of http, is there any particular settings at the level of the IIS to let it work?
Thank you
Best
Jamal
Jamal Numan
CamBarnard
Hi Jamal,
In all my use of GeoEvent I haven't had to make any special adjustments in settings to IIS.
-Cam
JamalNUMAN
Many thanks Cam,
Then why I couldn’t start the GeoEvent manager?
https://localhost:6143/geoevent/manager/index.html
Does it work with http instead of https?
Jamal Numan
MarkChambers1
Hello Jamal,
I am experiencing the same problem.  Have you been able to resolve this issue?
Thank you,
Mark Chambers
JamalNUMAN
Hi Mark,
I have been advised to open the “wrapper.log” file stored in the path below:
C:\Program Files\ArcGIS\Server\GeoEventProcessor\data\log
This should tell the reason why the GeoEvent manager doesn’t start.
Best
Jamal
Jamal Numan
CamBarnard
Ahhh ... so it wasn't that IIS settings needed to change to have you access GeoEvent manager but rather that GeoEvent manager wasn't actually running!
Thanks for the update Jamal Miah
Cam
