GeoEvent Configuration: Turning Log Messages Off
449
08-23-2019 07:52 AM
EricIronside
Sometimes a log message appears at the ERROR level that you temporarily/permanently need to turn off.  However, the GeoEvent User Interface doesn’t allow you to turn logs off. To get around this, you can do it using the GeoEvent Configuration Files.
1. In GeoEvent Manager, set the log level on the logger you want to eliminate to ERROR. Repeat for each logger. Some examples of loggers that you may decide to turn off.
                    Logger: com.esri.ges.httpclient.Http
                    Logger: com.esri.ges.fabric.internal.ZKPersistenceUtility
2. On the GeoEvent machine, edit the following logging configuration file (NOTE: On Windows you will need to run the editor as Administrator)
                    <GeoEvent Install>\etc\org.ops4j.pax.logging.cfg
3. For each of the logger names above (from Step 1):
         a. Search for the logger name string from above, you should find a .name record like the following:
                    log4j2.logger.com_esri_ges_httpclient_http.name = com.esri.ges.httpclient.Http
         b. Change the .level record for that logger .name record to be OFF
                    log4j2.logger.com_esri_ges_httpclient_http.level = OFF
4. Save your changes and close the .cfg file.
5. Restart GeoEvent to be sure it picks up the new logger settings.
3 Comments
GeoHowl
Is there an updated name for the ZKPersistenceUtility? I couldn't find that entry in the config file at all.
EricIronside
In order for the loggers to show up in the configuration file, you must perform step #1 above (in GeoEvent Manager set the log level of the logger you wish to silence to ERROR).  Once you've done that step, it should show up in your configuration file.
GeoHowl
That worked. I read through but didn't absorb that, new to GeoEvent and hadn't set any loggers yet. Thanks for the help!
About the Author
Esri Professional Services Real-Time GIS Team GeoEvent Sr. Product Enginner
