Backups failing in Oracle geodatabase
1688
09-23-2019 12:27 PM
TCEQGIS_Team
Our backups have started failing in our Oracle geodatabase. Below is what we are seeing in the logs. Does anyone know of a solution or can provide any suggestions?
Error in expdp log:
20-SEP-19 22:31:19.788: Processing object type DATABASE_EXPORT/SCHEMA/TABLE/INDEX/DOMAIN_INDEX/INDEX
20-SEP-19 22:31:21.282: ORA-39127: unexpected error from call to local_str := SYS.DBMS_EXPORT_EXTENSION.GET_DOMAIN_INDEX_METADATA('A784_IX1','GDB_ADM','ST_DOMAIN_METHODS','SDE','12.02.00.00.00',newblock,0)
ORA-20083: No ST_SRID supplied in PARAMETERS clause.
ORA-06512: at "SYS.DBMS_EXPORT_EXTENSION", line 274
ORA-06512: at "SYS.DBMS_ODCI", line 228
ORA-06512: at "SDE.ST_DOMAIN_METHODS", line 2723
ORA-06512: at "SDE.ST_DOMAIN_METHODS", line 2696
ORA-06512: at line 1
ORA-06512: at "SYS.DBMS_SQL", line 1721
ORA-06512: at "SYS.DBMS_ODCI", line 220
ORA-06512: at "SYS.DBMS_EXPORT_EXTENSION", line 250
ORA-06512: at "SYS.DBMS_METADATA", line 10071
ORA-06512: at "SYS.DBMS_SYS_ERROR", line 95
20-SEP-19 22:31:27.244: Processing object type DATABASE_EXPORT/SCHEMA/TABLE/POST_TABLE_ACTION
ChristianWells
Can you check the "PARAMETERS" and "DOMIDX_OPSTATUS" of the index in Oracle?
select * from all_indexes Where index_name like 'A784_IX1';
If PARAMETERS is blank or DOMIDX_OPSTATUS is marked as "FAILED", we will need to update the index properties in the Geodatabase through ArcCatalog.
by Anonymous User
Not applicable
Thank you, Christian. It was blank. The index wasn't visible from ArcCatalog, but was visible from Toad. We dropped the index using Toad and then used ArcCatalog to release the locks and create a new index. Thanks for your help.
ChristianWells
I'm glad to hear this resolved the issue, Chris. Have a good day!
