GeoAnalytics Performance: ArcGIS Pro or Portal
419
03-08-2018 05:03 AM
deleted-user-4ympgHKYfQv_
New Contributor II
which platform would you suggest in terms of performance to excecute analysis: ArcGIS Pro or Portal?
Or isn't there any difference at all?
Thanks for your help!
Carsten
SarahAmbrose
Hi Carsten,
There shouldn’t be a difference in performance at all. When you run a GeoAnalytics tool through the portal ma viewer and Pro it’s executing the analysis on the GeoAnalytics Server. The time to pass the information from Pro to the GeoAnalytics Server and the Portal Map Viewer to the GeoAnalytics Server should be very similar.
There are other reasons to choose one experience over another, but it’s mostly based on personal choice. For example, there are more verbose messages in Pro on the status of the job, while the Portal experience is more simplified.
Sarah Ambrose
Product Engineer, GeoAnalytics Server
