Troubleshooting guide for ArcGIS Spatiotemporal Big Data Store
4056
07-11-2016 03:07 PM
SagarAyare
New Contributor III
2 0 4,056
Many of you may have across following errors while setting up ArcGIS Spatiotemporal Big Data Store:
  • None of the configured nodes are available: []
  • Server error code 500 (Failed to create the service 'Hosted/BDSserviceName.FeatureServer'. null)
Please make sure you have imported the SSL certificate from "https://portalMachine.domain.COM:7443/arcgis/sharing/community/self?” into GeoEvent's site via the ArcGIS Server Admin API.
Root Cause: "PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
This troubleshooting guide describes the general troubleshooting steps to fix the above errors. It also highlights:
  • ArcGIS Installation Order for Web GIS and Spatiotemporal Big Data Store
  • Ports used by Spatiotemporal Big Data Store
  • Under the hood process for Writing and reading from ArcGIS Spatiotemporal big data store
  • Verifying the Certificates used by the GeoEvent Extension
  • Verifying the connection to bds-server
  • Describedatastore.bat command
  • Unable to publish ArcGIS big data store Feature service and map service when Tile Cache data store is enabled.
  • Using a Single Machine Architecture
  • Enabling Different Data Stores on the Same Machine
  • Portal for ArcGIS Requirement in your Web GIS
  • Hosting Server Requirement in your Web GIS
  • Domain Requirement when Enabling Spatiotemporal Big Data Store
  • Directory Requirement when both Relational and Spatiotemporal Big Data Stores are on the Same Machine
  • Federation without ArcGIS Web Adaptor for ArcGIS for Server.
  • Using IWA Credentials for Connection to Portal for ArcGIS from GeoEvent Manager
  • Updating the Hostname with the Internal IP address on Amazon/Azure Instances.
  • To Unregister the Spatiotemporal Big Data Store and Start Over
You can consider this guide as the answer to the Frequently Asked Questions (FAQs) for ArcGIS Spatiotemporal Big Data Store.
The troubleshooting Guide is bundled with the tutorial for Spatiotemporal Big Data Store & can be downloaded from the following location:
http://www.arcgis.com/home/item.html?id=870b1bf0ad17472497b84b528cb9af00
Feel free to post your comments, questions and valuable feedback here.
Hope this info helps.
Sagar Ayare | Product Engineer
Real-time GIS
