The data which is generated as Mobile cache by "Create Mobile Map" tool in ArcToolbox will be available in .db file.
I have a question here, can we generate the cache in any other file format like sql or anyother format which is generic to all the other applications. If Yes what are those other formats which ArcGIS Mobile will be able to support?
If in case ArcGIS Mobile supports only.db files then will SQL-Lite allow other applications to use the data available in .db file .
Any ideas or views on this query will me highly appreciated.
Thanks in Advance.
Thanks & Regards,
Vijay Kumar V
