Hi,I followed the GlobalFeatureMenuCustomizationExtension sample to add a menuitem to the FeatureListBox. So far everything is fine. To avoid cluttering my extension's class, I tried to put all the menuitem's code in a separate class, and although it still works, the menuitem's caption now has an offset of a few pixels to the left, see the attached image.I'm sure I'm missing something obvious, but I can't seem to find what it is. Please help!Here's the Extension's code:private void FeatureListBoxCreatingFeatureListBoxMenuItems(object sender, CreatingFeatureListBoxMenuItemsEventArgs e)
var item = new TestMenuItem(e.FeatureListBox);
e.FeatureListBox.MenuItems.Add(item);
And here's the MenuItem's code:public class TestMenuItem : MenuItem
private readonly FeatureListBox _listBox;
public TestMenuItem(FeatureListBox listBox)
_listBox = listBox;
protected override void OnInitialized(EventArgs e)
base.OnInitialized(e);
Command = new RoutedUICommand("ClickMe", "ClickMeCommand", GetType());
CommandTarget = _listBox;
IsVisibleChanged += ItemIsVisibleChanged;
var binding = new CommandBinding(Command);
binding.Executed += BindingExecuted;
_listBox.CommandBindings.Add(binding);
static void BindingExecuted(object sender, ExecutedRoutedEventArgs e)
// Execute command
private void ItemIsVisibleChanged(object sender, System.Windows.DependencyPropertyChangedEventArgs e)
// Determine if menuitem can be enabled
