error opening mobile cache
592
09-26-2011 06:26 AM
JoeZuckerbraun
New Contributor II
This is a newbie question here but I have to start somewhere.
I created a mobile project using ArcInfo 10 and can run the mobile application on the desktop, but when I copy it over to a the mobile device I get the message 'error opening mobile cache'.
Is anyone familiar with this issue? Is there some other way of transferring the project other than a copy/paste or synchronize?
Help would be appreciated!
-Joe
LucasBannan1
Hey, not sure if you have figured out an answer to this problem, but I found this article by ESRI that may help you out.
http://support.esri.com/en/knowledgebase/techarticles/detail/38116
Hopes this helps.
BradleyJanke
New Contributor III
Hopes this helps.
That link provides the answer.  When you open your mobile project DO NOT select Overwrite Existing Mobile Project.  If you do it will erase the MobileCache you just implemented and try to obtain a new cache.
