Error: Attempted to read or write protected memory.
4596
03-31-2015 10:00 AM
ShaneLim
I have created a mobile map service with uploads enabled.  I have no errors in the ArcGIS server Manager Logs.  Inside the water utility mobile map and inside the Mobile Poject Center I am unable to access the mobile service with the soap url getting the following error.
Error: Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
I have a mobile map service running currently and the one I am publishing is simply that mxd with a few different layers. I am using the latest version of the Water Utility Mobile map and Mobile Project Center 10.2.0.0
Server Version
License level:  ArcGIS for Server Advanced
Expiration Date:  Never
Software version:  10.2.1 (build 3497)
screenshot from mobile project center below.
Any ideas?
Shane
MattFlowerday1
Can you access the rest Url?
Are you using a mobile or feature service?
Sent from matts iPhone
ShaneLim
I am using a mobile service and accessing it with the rest url : http://njhpbgiswp01:6080/arcgis/rest
I can see both the working and broken mobile services.
I have added them both, set the extent and validated.  One works the other does not.
I can view them in ie using the rest url as well. http://njhpbgiswp01/arcgis/rest/services/UWID_MobileFlushing/MobileServer
