Hi there
I set a mobile project with several layers as an operational layers and a one raster layer as a base map layer with about 4 to 5 Gbytes cache. I found out the ArcGIS Mobile Application 10 proved quite unstable, corrupting or invalid the projects due to various causes:
1. If the application is blocked and we have to forcibly shut down;
2. In a process of data synchronization via GPRS (post updates and get date);
3. ...
This issues forcing teams on the ground to re-download the project, losing the information that was not published to the server.
For your information, the regional settings are set to Portugal (Portuguese) and the project is an SD-card flash memory.
I would appreciate any help, only to confirm these instabilities that may inhibit the development of an entire project.
