ArcGis For Windows Mobile 10.1.1 SketchCollectionMethod is missing
2598
12-08-2013 09:25 PM
JérémiePedoia
I am facing an issue while trying to listen GeometryCollectionProgress.
On my CollectFeatureTask.CollectionStarted, I wish declare GeometryCollectionProgressEvent.
Here is my simplifiyed code:
    private CollectFeaturesTask _collectFeaturesTask;
    protected override void OnOwnerInitialized()
            _collectFeaturesTask = MobileApplication.Current.FindTask(typeof(CollectFeaturesTask)) as CollectFeaturesTask;
            if (_collectFeaturesTask != null)
                _collectFeaturesTask.CollectionStarted += new EventHandler(_collectFeaturesTask_CollectionStarted);
                _collectFeaturesTask.CollectionCompleted += new EventHandler<CompletedEventArgs>(_collectFeaturesTask_CollectionCompleted);
 void _collectFeaturesTask_CollectionStarted(object sender, EventArgs e)
        _collectFeaturesTask.EditFeatureAttributesPage.GeometryCollectionViewModel.GeometryCollectionMethods[0].GeometryCollectionProgress += new EventHandler<GeometryCollectionMethodsEventArgs>(GeometryCollectionProgress);
    void GeometryCollectionProgress(object sender, GeometryCollectionMethodsEventArgs e)
        //Do something with the sketch geometry when GeometryCollectionProgress is over
I do not understand why GeometryCollectionMethods is limited to GPSVertex (not working by the way).
The SketchCollectionMethod is missing despite this Arcgis Help extract :
By default, it contains the following built-in geometry collection methods:
Sketch
GPSVertex
Streaming
Source
and this one:
The Sketch geometry collection method, however, cannot be removed.
from here.
Any help will be very kind.
Thanks in advance.
Regards.
J.
