Using MicroStrategy Web 10.3 with Esri Maps for MicroStrategy
2206
05-11-2016 08:24 AM
KatherineFitzgerald
New Contributor III
The MicroStrategy Community announced the release of MicroStrategy Web 10.3 in March of 2016. MicroStrategy Web 10.3 is an incremental update release.
While Esri Maps for MicroStrategy 2.0.2 was shipped supporting MicroStrategy Web 10.0 and 10.1, the Esri Maps for MicroStrategy 2.0.2 MicroStrategy Web 10.2 Support and Update Patch was released to fixed critical bugs related to MicroStrategy Web 10.2.
MicroStrategy Web 10.3 has now been certified and is supported by v2.0.2 with this patch. In limited testing with Esri Maps for MicroStrategy 2.0.2 and this patch, no issues were encountered.
To take advantage of fixes in MicroStrategy Web 10.3, Esri Maps for MicroStrategy 2.0.2 can simply be installed on top of MicroStrategy Web 10.3 and the update patch applied. That means, if this patch has already been applied to V2.0.2, it is not necessary to install the plugin first.*
Read the MicroStrategy Web release notes.
* If you installed a new install of MicroStrategy Web 10.3, you must reinstall Esri Maps for MicroStrategy v2.0.2 before applying the patch.
For more information on applying this patch, see Esri Maps for MicroStrategy 2.0.2 MicroStrategy Web 10.2 Support and Update Patch.
~Esri Maps for MicroStrategy team
Reply
