I have a shared document library in SharePoint that I have added some address fields to and a geocoding workflow using the ArcGIS Online EU locator. The workflow works after it has been added but then when I add new documents to the library it always fails with a cancelled outcome and the error message below. If I run the workflow manually it does work, but I do not want people to have to do this.
Also when I open the document properties and edit the attributes I can edit the text fields but not the location like is available with a normal list. The Select, Fix & Update buttons are not available on the ribbon and I can seem to edit the location of the point manually.
Any ideas???
Your WorkFlow failed: Required parameter is null or empty.
Parameter name: AddressToLocationsParameters.Address. System.ArgumentException: Required parameter is null or empty.
at ESRI.ArcGIS.Mappi
