link for attachment in pop-up not correct
2565
12-20-2012 07:23 AM
KeithNightlinger
I have a sharepoint list that is using the ArcGIS plugin.  The list allows for attachments and I have them enabled to show in the pop-up.
The problem is the link to the attachement doesn't work
The link should be
http://server/site/Lists/listname/Attachments/5/picture.JPG
But is:
http://server/site//site/Lists/listname/Attachments/5/picture.JPG
You can see the map control is trying to append a relative path to the url of the site.
The link to the attachment works from the list, only when accessing through the map control.
Any help on this would be appreciated.
Thanks in advance.
rayterrill
Did this ever get resolved? Running into the same issue in our environment with 3.0.1.
KatherineDalton
Hi Ray,
I'm not able to reproduce this with the 3.0.1 ArcGIS Map Web Part, currently. Could you give me more details about the url you are trying to link to (web, within SP site, etc) and what the field type is (single line of text, hyperlink, etc) and I'll see if I can repro it and give you a status as to whether it might actually be fixed in the latest. I can say that we do have hyperlinks in pop-ups working correctly in the Esri Maps Web Part.
Katy
Katy Dalton | Technical Consultant
THE SCIENCE OF WHERE™
