Adding kmz/kml directly to Esri Maps for SharePoint is not supported, but you could create a map in ArcGIS Online and then open/add that map in either the Esri Maps Web Part (JavaScript) or ArcGIS Map Web Part (Silverlight).
Hope that helps,
Katy
I have tried this and the kmz layer does not render in either the ArcGIS web part or the ESRI wed part. The map does render.
I am on an SP site with HTTPS enabled and I have followed the instructions to set things up for this scenario but there is a Layer Initialization error - the language in the error references a security exception.
Has anyone come across this?
Paul
