Connect ArcGIS Maps for SharePoint to Portal/Enterprise instead of AGOL?
6229
25
04-13-2021 08:44 AM
PamelaLocke1
I was wondering if you can connect Maps for SharePoint to a Portal/Enterprise log-in, instead of ArcGIS online?
Thanks!
Pamela
TheGreenOrange
RaajRaaj
@TheGreenOrange
Hello,
ArcGIS for SharePoint supports both ArcGIS Online as well as ArcGIS Enterprise.
On the main sign in page after you add the "ArcGIS for SharePoint" app to a SharePoint page, you will see the default option which is ArcGIS Online. But you should also see a second option "Enter url address", which should allow you to enter the url for your enterprise portal.
Also, please make sure you have the latest version of the app which can be downloaded from the MS store.
https://appsource.microsoft.com/en-us/product/office/wa200003118?tab=overview
Please let me know if you have any questions.
Thanks & Regards,
Raaj
TheGreenOrange
Hi, I have version ArcGIS for SharePoint (2024.2.2.1888) There is no option to use enterprise. There is no Enterprise log in.
Both options force me to log into arcgis Online
ArcGIS Login points to arcgis online, as you can see from the screenshots below:
Your ArcGIS organization's URL (Points to arcgis online)
Internally with things like pro I have the option to log into either portal or online.
RaajRaaj
@TheGreenOrange - Can you send me a screen recording showing the ArcGIS for SharePoint UI?
Thanks & Regards,
Raaj
TheGreenOrange
Hi, This is what my initial sign in screen looks like:
Then when I click on "Sign In" I am presented with the popup screen with the option for
ArcGIS Login or Your ArcGIS organization's URL account, like I just posted. Both of these take me to our arcgis online
like i said, I do not see any option for Enterprise login. What should it look like? I think there is something missing here.
RaajRaaj
@TheGreenOrange - Can you try clearing cache and reload the page? Once you do that, you should see the initial sign in screen which should allow you to select "Enter URL address" where you can enter your Enterprise portal url.
Please let me know if you are still don't see the initial sign in screen.
Thanks & Regards,
Raaj
TheGreenOrange
I can try, but I only got this installed two days ago and it's always been like this, both Firefox and Edge. i am talking to our Sharepoint team to see if there's an internal restriction in place or something preventing it. i gave them the URL of one our TEST portal.
TheGreenOrange
Can you show me what the initial sign in screen should look like? I can pass this on to our Sharepoint team for them to see.
RaajRaaj
@TheGreenOrange - Here's a screenshot of the initial sign-in screen. You can also ask your Microsoft admin to set up the connection strings (in case you don't want to manually enter the portal URL) to your portal which would allow you to pick the portal from the drop-down that you'd like to connect to. I've blurred out the connection strings set up in my Microsoft tenant.
At the very bottom of the list, you can see the "Enter URL address" option. Once you select that option, you will see a text box where you can enter the URL for your portal.
Hope this helps.
Thanks & Regards,
Raaj
TheGreenOrange
I don't see that. This is what I see:
Then when I click on the orange sign in bar, I get this, both of which take me to our argis online account:
