Attachments don't work in SharePoint 2013
2991
09-18-2014 07:53 AM
AaronWeier2
New Contributor II
Hi All,
I'm using the Silverlight ArcGIS Map Web Part. In the map I have one layer coming from our own ArcGIS app server as a feature service. I can add a feature as a point and edit values but I'm unable to add attachments. I have attachments enabled on the feature class in the geodatabase and can see the 'add attachments' icon in the pop up but when I click on it nothing happens.
Anyone else have this issue? Thoughts on how to fix it?
thanks,
Aaron
CarrieDavis
Hi Aaron,
This capability is available for feature services in the Silverlight web part for SharePoint 2013 within the pop-up for the feature. At the REST endpoint for your feature service make sure that the attachments property set as 'true'.   If so you should be able to add the layer as a "feature layer" to the map contents in the web part. Enable pop-ups and configure that layer to be editable.  Then the add attachment icon should be accessible. addAttachments.jpg
