When creating an ArcGIS Location column in Sharepoint 2010 (we are using 2.1.1), the "Location Settings" Silverlight control appears and allows me to select X/Y fields. When I choose the Address Fields tab, the Silverlight control disappears completely. If I choose a different field type and then re-select ArcGIS Location field, it appears again, but the same behavior occurs when I select the "Address Fields" tab. The third tab, Map Options, works fine.
Our locator service is SSL, as is our Sharepoint 2010 environment.
Any suggestions? Thank you.
Matt
Amherst, MA
