An invalid ArcGIS Portal URL was entered. Please verify the URL.
7980
19
02-01-2014 08:39 AM
TomerSteinberg
Hi all,
i am using the add-on for Business objects dashboards. when trying to open the ESRI maps designer for Business objects dashboards i am getting the following error after i log in with my https://www.arcgis.com credentials:
does anyone have a clue?
thanks,
tomer.
ShirleyBaffoe
Hello Tomer,
From the error message, I am assuming you are trying to connect to an ArcGIS Portal. The message means there is have an error in your settings.js configuration file (which is located in <Tomcat installation directory>\webapps\em4bobj\dashb\configuration\settings.js). Verify that you have entered the correct portal URL for the arcgisUrl property field. The settings in the file should look like this
        arcgisUrl: "[URL to ArcGIS organization]�?�,
       //for example: "http://portalhost.esri.com",
       arcgisAuthType: "user",
       arcgisAppUser: "",
       arcgisAppPassword: "",
       arcgisAppId: ""
For more information on configuring the authentication please refer to the documentation http://location-analyticsdev.arcgis.com/en/maps-for-sap-bobj/install-and-configure/configure-login-s...
Hope this solves your problem.
Shirley
TomerSteinberg
Hi Shirley,
I'm actually trying to connect to the arcgis.com .
What could i be missing?
currently my settings is like that:
arcgisUrl: "http://sap-israel.maps.arcgis.com",
//for example: "http://www.arcgis.com,
arcgisAuthType: "app",
arcgisAppUser: "myuser",
arcgisAppPassword: "mypassword",
arcgisAppId: "myappid"
//for example: "nvgHDDFXzMRWmKfY
what do u think?
thanks,
tomer.
ShirleyBaffoe
Hello Tomer,
If you are connecting to your ArcGIS organization using app login, then your settings.js file should look like this:
arcgisAppId: " "
The arcgisAppId field needs to be empty.
Shirley
TomerSteinberg
i have tried that now.
it is still similar. could this be related to proxy?
thanks,
Tomer.
ShirleyBaffoe
Hello Tomer,
If you haven't done so already, please restart your tomcat web server, clear your IE browser cache and re-launch the designer.
A simple test to verify if your proxy is working is try to access the following URLs in your browser:
1. http://[URL to ArcGIS organization]:[port number]/em4bobj/dashb/proxy.jsp?http://www.arcgis.com/features/img/logo-esri.jpg
e.g. http://sap-israel.maps.arcgis.com:8080/em4bobj/dashb/proxy.jsp?http://www.arcgis.com/features/img/lo...
and
2. http://[URL to ArcGIS organization]:[port number]/em4bobj/dashb/proxy.jsp?https://www.arcgis.com/features/img/logo-esri.jpg
e.g. http://sap-israel.maps.arcgis.com:8080/em4bobj/dashb/proxy.jsp?https://www.arcgis.com/features/img/l...
If you are able to see the Esri logo in your browser then your proxy works as expected.
Shirley
TomerSteinberg
OK.
i'm getting on both
and
Network Error - Proxy: Raannana(RAA01-2)
so - where do i configure that?
in my browser settings?
I have no problem to access anything else over the web.
by Anonymous User
Not applicable
When we try to connect to our internal portal, how do we tell the client to connect to our internal portal?  It is still sending us to our ArcGIS Online account.
ShirleyBaffoe
Hello Allison,
Esri Maps for SAP BusinessObjects can be configured to use an on-premise Portal for ArcGIS deployment in the settings.js configuration file. This file is located in <Tomcat installation directory>\webapps\em4bobj\dashb\configuration\settings.js
Open the settings.js file in any standard text editor, such as Notepad++ and provide the url of your Portal for ArcGIS as the value for the arcgisUrl property. The Url must be enclosed in quatation marks (" ") and should be in the format http://[PortalHost]/[PortalApp]
For example:The settings should look like this
arcgisUrl: "[URL to Portal for ArcGIS]�?�,
//e.g. arcgisUrl: "http://portalhost.esri.com/gis",
arcgisAppUser: "",
arcgisAppId: ""
For more information on please refer to the documentation http://location-analyticsdev.arcgis.com/en/maps-for-sap-bobj/install-and-configure/administrative-an...
Shirley
by Anonymous User
Not applicable
Thank you, however we had tried just that and the map designer still opens ArcGIS Online and asks the user to sign in to ArcGIS Online.  The link in the post above is broken when I try to access that site.  So we switched our setup back to ArcGIS online settings and now we can publish to ArcGIS Online but we cannot view the map/data within the dashboard.....we have not had much success in trying to set this up, unfortunately.  Also, one user can sign in successfully to ArcGIS Online through the mapping tool, but another user cannot.  Any feedback on any of these issues is greatly appreciated.  Thanks again.
