Power BI Map visuals not showing when published to web
3609
08-21-2023 08:05 AM
Labels (3)
RUIFLAMINOSANTOS
I Publish my BI report to the web however the map visuals are not displaying in the published dashboard, they work just fine in power bi desktop and online. It appears a message saying "este elemento visual não é suportado nos seguintes cenários: Live Connect para incorporar e publicar na web não autenticado por utilizado, publicar para a web e power bi server" google translated to "This visual element is not supported in the following scenarios: Live Connect for embedding and publishing on the web not authenticated by the user, publishing to the web, and Power BI server"
LeslieUK
Hi @RUIFLAMINOSANTOS
For embedding can you confirm that you validate in the Settings pane, in the Embed and publish check category?
Can you also check that your report meets these requirements: Embed a map-enabled report—ArcGIS for Microsoft 365 | Documentation
~Just trying to fix things~
RodPBI
Yep, that’s a self-imposed limitation of the visual. My understanding is that you must share the report with people who are licensed and have permissions in PowerBI for the visual to work.
