Maps got broken in the last update
8644
26
09-01-2021 08:14 AM
AlbertPorterosVillar
Hi all,
From this morning, I am getting this message where it used to be the map whenever I publish the dashboard.
Any idea of how to solve it? All my maps disappeared.
Regards,
Albert
JonEmch
Can you confirm that you are signed into the ArcGIS for PowerBI visual in PowerBI Online??
Keep on keeping on!
It's happening to me even on my desktop version. I didn't touch anything since yesterday so what has changed here?
by Anonymous User
Not applicable
@AlbertPorterosVillar There was an update that went out, and unfortunately it is having a negative impact. We are evaluating deploying fixes or rolling it back.
@Anonymous User Do we have any timeline? I work for HP and we were going to deploy an important asset, that won't be able to see the light until this gets fixed.
Thanks a lot for the information provided.
by Anonymous User
Not applicable
@AlbertPorterosVillar We are evaluating that now and looking to have some sort of solution in place by next week. While we can patch quick, the rollout across the environments takes time.
Few things to try.
1. Create a new tab, add the map there and add some data to it. Save the report and see if you get prompted on the original map. If it resolves the issue, delete the tab and save the report. Test again.
2. Create a new tab, add the map there and sign in. Once you've signed in, save the report. Reopen and test the original map. If it resolves it, sign out of the map in the new tab and delete the tab. Save the report and test again.
3. If this does not resolve your issue, DM me and I'll connect with you over the phone.
@Anonymous User Thanks for the update.
If I create a new map, it seems to work fine, but I cannot copy the format from the old one, so I would like to conserve the old ones for sure.
I tried number 1, the old map didn't work at any time.
In number 2, I don't have any option to sign in.
by Anonymous User
Not applicable
@AlbertPorterosVillar If I add a new map and login, I can get it working. You sign into the map on the second tab, save it, log out, save it. It resolved an issue for my report. If you need an account, let me know.
Good news we do have a fix for it and hoping it will go out soon.
Hi @Anonymous User , I don't have any account, I was just using it without having account, how can I get one without any billing if possible to keep the dashboard working as it used to?
by Anonymous User
Not applicable
@AlbertPorterosVillar Shoot me a DM with your contact info and we'll get you an account.
